Old 05-26-2014, 04:37 PM
robert1's Avatar
robert1 robert1 is offline
I would suggest that you check all the resistors in the vertical oscillator / output circuit to see if they did't drift out of spec. there are several 1 meg & higher resistors used in that circuit & they ARE prone to drift.
i restored a 19A11 in the late nineties & found the same problem.
