Old 05-30-2014, 07:13 PM
pac.attack76's Avatar
Stuck in the past
RCA Selectavision model SJT-090 problem.
Makes a sound when plugged in and flashes the letter "L". Putting a disc in does nothing. Is this a belt off? If so, how do i get to it? Can't see anything from the top.
Old 05-31-2014, 01:58 AM
Does the disk stay in like it should, after you pull the sleeve out?
Old 05-31-2014, 01:53 PM
Stuck in the past
Well, i noticed the door was never closed from the beginning. While cleaning, i decided to rotate the white gear in the back right corner next to the fuse. Doing that closes the door and changes other things. Couldn't get it to load on its own and was real hard to get to sleeve to pull out once it was all the way in. Finally got sleeve pulled out leaving disc inside. disc was slightly forward maybe a thirty second of an inch. tapped back and centered on post. Hit play and started movie and actually played great. What's wrong with the loading/unloading sequence?? Seems like timing issue or a sensor. Any ideas?
Old 05-31-2014, 02:42 PM
That's great that you were able to get a disk to stay in place and play!
I really know nothing about the auto load/unload mechanism.... mine was an earlier manual load model with a lever on the front. hopefully, somebody here will have knowledge of the later auto load models.
Old 05-31-2014, 03:50 PM
ChrisW6ATV ChrisW6ATV is online now
Nice to hear that your machine plays video OK. That means its stylus is good.
Old 05-31-2014, 08:53 PM
Take a look at http://www.cedmagic.com/home/technic...tion-page.html and maybe there's a solution to your problem there.
Old 05-31-2014, 09:59 PM
Stuck in the past
I was just about to post there too. I'll check that out.
Old 06-01-2014, 02:11 AM
Stuck in the past
Thumbs up
Looked closer and found a missing belt in the back left. All is well now. Working 100%.
Old 06-02-2014, 03:06 PM
Dude111 Dude111 is offline
Analogue is Awesome
I was gonna suggest doing so
Good for you pac!!!!! (I wanna get one also (A mono one))
Old 06-03-2014, 12:23 PM
Stuck in the past
That's what this one is. Got it hooked up to my 1984 RCA XL100 25" console which is mono as well.
Old 06-03-2014, 10:14 PM
Analogue is Awesome
Excellent
Ya watched any movies yet??
Old 06-04-2014, 12:12 PM
Stuck in the past
Excellent
Sure. So far, Star Trek II: The Wrath of Khan, Star Trek III: The Search for Spock, Star Wars, 007 James Bond: Never Say Never Again, White Lightning, Benji, Thumbelina, Sands of Iwo Jima, 007 James Bond: Goldfinger, Star Trek series: Space Seed/The Changeling, Starman, Twilight Zone: The Movie, Wargames, Tron.
Old 06-09-2014, 08:24 PM
Analogue is Awesome
Ahhhhhhhhhhhhhhhhhhhh!!!
Good for you buddy
