I decided to check mine after all, but you'd better double-check what's coming off those pins in the schematic. I've got two red wires on the back of the chassis plugged into a board with two rows of vertically-arranged solder cones, next to the power tranny and a big filter can. They're plugged into the lower-right pins, not including the pin holding the board in place which it probably wouldn't fit anyway.
