Old 07-21-2014, 09:56 PM
Tubejunke's Avatar
I'm glad that this thread was made, and even more glad concerning the outcome of Schanz's radio. Reason being on the former is that I have an old Delco R-1125 with a #80 rectifier that has been giving me fits. Basically the B+ is really low and I can't find a reason why so far. The transformer gets really hot after about a half hour.
I replaced the filters and a number of the non polarized caps. I haven't done the things mentioned here as far as having all leads open and checking the resistance of windings and shorts between windings or to ground. The main reason is that the wiring is so hard that I feel that it would be destroyed by moving it much. The insulation under chassis is good as it stands. I popped the covers on the trans. and it wasn't very pretty, but didn't seem to be smoked.
Like Shantz, I feel that opting for a replacement trans. would save a lot of time and aggravation. I don't know where I would find one, but if anyone does please let me know. Thanks!
Old 07-22-2014, 09:16 AM
Schanz's Avatar
Schanz Schanz is offline
Pioneer Stereo Fan Club
Could be that you need to replace all the caps first. I don't know that the smaller down stream caps can heat your transformer like that but I'm no expert by any means.
I put mine all together last night finally but when I turned it on I heard a small electrical arc. Uh oh. I found one my 22uf electrolytic caps had come loose from the ground. Repaired the solder but now the sound is gone. Replaced that cap but that didn't fix it. Voltages at the rectifier are fine. All tubes light up but my b+ voltage is missing farther down the circuit if that makes sense. Haven't had time to investigate much yet. Frustrating.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Looking for a dial glass and knobs for a R-30s Fisher console.
Old 07-22-2014, 09:47 AM
Make sure that both electrolytics don't go to ground. The C-25 negative goes to the center tap of the transformer and speaker field as the choke and forms the bias supply for the 42 tube. It could be that the R-13, 235 ohm resistor opened. As a result of this resistor opening, there won't be any B+ to the rest of the set, not even a hum. They usually used those flexible type resistors. Replace with at least a two watt wire wound resistor.
Old 07-22-2014, 10:34 AM
Schanz's Avatar
Thanks. I'll check r13. It's one of the few original ones left. C26 is the only one that goes to ground and is the one that popped loose. Quick question though. I can measure 360v across C25 (pos to neg lead) but nothing across C26. It's that proper?
Old 07-22-2014, 10:54 AM
maxhifi's Avatar
maxhifi maxhifi is online now
Impossible to tell without seeing the schematic
Old 07-22-2014, 11:10 AM
Schanz's Avatar
Right.
Old 07-22-2014, 12:42 PM
The field coil and the R-13, is the only return to chassis ground. Did you check the 235 0hm and the field coil. It should read around 1050 ohms.
BTW, the speaker should be plugged in, to complete the B+,B- circuit.
Old 07-23-2014, 08:08 AM
Schanz's Avatar
I get about 1100 ohms on two pins of the speaker plug while disconnected so maybe we're ok there. R13 seems to check out ok also. It's an armored wire wound thing attached to the chassis. Voltage before the field coil was about 230 vdc. It was about 30 vdc after. Still getting approx 30 vdc after r14 but nothing after r15. This was done really quickly on my way out the door this morning. I'll replace both r14 and 15 tonight and measure again.
Old 07-23-2014, 08:46 AM
So far, everything in the bias supply, seems to be in order. I wouldn't worry about the R14, R15, at this time!
I can't see why, there is no B+ at the C26, measured to ground.
The voltage chart is on page three of the Rider's.
The B+ measured from the + side of C-26, should be around 240 volts, DC, to chassis ground.
Old 07-23-2014, 11:31 AM
Schanz's Avatar
Hmmm...
Could C25 be bad? It is a replacement that was done some time in the past by someone else.
I believe I will go through this thoroughly when I have more time and write voltages on the schematic.
Old 07-23-2014, 01:58 PM
Hmmm...
It would have to shorted big-time. You voltages on the bias source seem to be right.
Keep us informed!
Old 07-23-2014, 10:38 PM
Schanz's Avatar
Took some measurements and wrote down some voltages.
The speaker makes a little buzzing and the back of it gets hot. Never really felt the speaker coil before.
Old 07-24-2014, 02:18 AM
Giulio Maiocco's Avatar
Giulio Maiocco Giulio Maiocco is offline
Geloso prototype owner
Careful here, Schanz, if the voltages you reported are right, you are pulling way too much current from the 80 rectifier and power transformer. The field coil shoud get warm over a hour or so, but you say the field coil on the back of the speaker becomes hot, this confirms overload.
Just to start, with the radio unplugged, what's the resistance reading between the 80 filament (doesn't really matter which one of the two) and the chassis? With the symptoms you describe, I would expect a very low resistance, if this is the case, this is not right. Check C26, C28, the primary of the OPT and the 42 tube for shorts to chassis, or, failing these checks, the wiring carrying the B+ voltages around in the radio. Avoid as much as possible to plug in and turn on the radio, as this may cost you another power transformer / 80 tube / field coil! Oh, BTW, I hope that 6VAC on the 80's filament is a mistypo, as this would ruin the tube in a short time
Just let me know if I can help you further
Giulio
Old 07-24-2014, 08:07 AM
Schanz's Avatar
Yes Giulio, something was definitely wrong. Your comments got me thinking so before leaving for work this morning I checked everything carefully with a flashlight. I found my transformer had shifted and my make-shift mounting bracket had shorted a leg of the 80 to the chassis. That explains the missing voltage. Amazingly, the radio still works. The transformer will get a permanent mounting solution and all bare leads will get insulated.
And yes, that 6v on the 80 was a mistake. It is actually 5.25.
Old 07-24-2014, 08:19 AM
I think you found your problem , once you fix your PT in a secure and permanent way, I bet you'll find your 240V or so volts between the 80's filament and chassis and, important thing, you'll find the negative voltage generated across the 235 ohm will be quite less than your -31.6V, it should be roughly -17V.
With that dead short, no wonder you heard a pop/arc!
Ok also about the 5.25V on the rectifier's filament, much much better!
Best regards
Giulio
