Focus problem found: a previously good 8.2 meg 2 watt carbon
composition resistor which should have 2800 volts across it (0.95 watt) measures 27 megohms. Luckily I have a 10 Meg HV resistor I can use, which likely will put the focus voltage in range. Also. its in the HV cage which can be serviced without removing the chassis from the cabinet. |
