Old 09-10-2014, 09:49 PM
Originally Posted by centralradio View Post
GE was famous for those line operated table radios and clock radios.Be careful around the HOT dropping power resistor plus the high voltages.
What was the big deal for them not putting a power transformer in the set.Copper was not that expensive then.
I'm glad you got it working better.
They all seemed to do that, including Zenith. The high voltage silicon audio output transistor had a little higher wattage and they were able to use an output transformer, that was used in a tube set.
