the picture on the set originally was focussed on the left side and not the right. no matter what I, did the picture was fuzzy on the right side. I replaced the yoke, and this is when I stated when I tried to lay the set down it dropped ...I put the new yoke in and ..no picture, at all. I pulled the caps out of the new from Meyer's yoke and still, no picture. That is when I had to start putting the ion trap on the other side of the CRT neck to get the picture.
the electros are new, formed 450 volt caps. the diagram calls for 500. thats part of the reason I put a voltage dropping resistor in the power cord to keep the b plus as close to diagram as possible which may still be too high in the long run. my diagram is in my car and my wife has it. i think the b plus line should be 370 or 390 ish.
Here'ya go!
Let The Pep Boys help!
when I first got this set, The 16rp4 that was in it did not have an aquadag or a springy finger to ground the crt coating to the chassis. I did have a thread where I asked where did the shutoff dot go?.
Checking things that members have suggested to check now I found that my different 16rp4 has the aquadag worn down to the glass by the springy finger that I bolted in . I moved it to a different spot and that probably is why the shut off dot is back again. |
I pulled them When I did not get a picture after the yoke was installed, thinking that they were keeping the yoke from working correctly, It did not occur to me that maybe I jarred something loose by dropping the set which caused me to need the ion trap on the other side of the crt neck. Last edited by radio nut; 07-13-2014 at 06:31 PM. Reason: Added more....again! |
I replaced the original yoke because the right side of the picture would not focus but the left side would, no matter what I did. now the picture is uniform all the way across. in my opinion it is a little fuzzy but my wife said its fine.
I do need new glasses ..... so maybe she is right but the last time I checked the 500,000 ohm resistor in series with high voltage crt line it was about 780,000 ohm's. so maybe that needs replaced. I have avoided that one do to the space below the 1b3 socket and the fact that even at my age my hands shake..........especially working in tight spots! If I am correct low high voltage can cause out of focus condition.....but I will even admit that sitting away from the set it does seem clear, just not as clear as other sets I have owned. these sets were ...well....higher quality Motorola or RCA units Last edited by radio nut; 07-13-2014 at 08:51 PM. Reason: can't put every thought in at the same time! |
I checked my diagram (Muntz M31 ,sam's set 108 folder 8) and my set does not have a 56pf cap that I can find from the center horiz winding and the flyback. Maybe I need one? My set also uses the alternate horiz. damper circuit listed off to the side.
Mine is chassis 16a2. Last edited by radio nut; 07-13-2014 at 08:52 PM. Reason: added more |
well lets see, I replaced the resistor mentioned earlier and it is away from the damper tube. Problem still there,
I wondered about the crt itself since it got bounced around. nope, replaced it and problem still there. I pulled the video out tube so the set would be raster only and the lines are still there....that was also without any signal. I am going to get new electro's that are 500 volts soon. just asking......I thought bad or leaky electro's would put lines all the way across the screen or a wavy pattern indicating 120 cycle hum? Plus earlyfilm had wanted to be to check for the cap in the yoke....should I just put one in or jumper in temporarily for testing? |
And I normally keep the box and directions and just put extra caps or nuts and bolts in those boxes but this time I threw everything out because that would be too easy! |
Oh, The horizontal linearity coil is nos and just like the original makes zero difference to the picture no matter what I do with it. I have run it all the way in and out slowly while watching the set and.......nothing.
I was able to get a hold of Moyer's electronics where I had purchased the yoke and they will copy and e-mail the mini diagram for the yoke so I will be able to buy/install correct cap or caps for it.
Well today I installed the correct value parts in the yoke for the ones I removed to make the new yoke match the original one (50mmf cap and a 1000 ohm resistor in series) and the problem in my opinion is worse. It (if I am correct) seems to get worse every time I turn it on, but it is sitting all week unused. OK, So next time I will put in fresh new 500 volt electro's and A current limiting resistor in the high voltage line and see what happens.
Well,I bought 600 volt electrolytic and installed them. The problem is less obvious. I did form them on a healthily for a couple of minutes butt that can't be a s good as running the set. I will see if the issue goes away after the electrolytic capacitors settle in to their new home.
Manny, moe, and jack make one of those for flat screen LCD tv's....?
