Old 09-22-2014, 01:59 PM
What voltages you getting on the horiz output tube....?
it's not hot is it...? All those low ohm resistors good...?
Are you getting a plate voltage...? (yes you can check it with no HV, no Osc running)
The HO tube has voltage on the plate, it's missing the voltage from the Osc tube as I recall. It's not getting hot though.
I'll check it when I get home tonight and report back.
