Old 09-24-2014, 05:06 AM
miniman82's Avatar
First Light: 1952-2011
If the outside isn't grounded well, you can get a nice static 'jolt' off it. Ask me how I know. Also the silver coating has a habit of flaking off, so the static charge has no where to go. Solution as with glass is to apply dag.
Evolution...
Old 09-24-2014, 12:07 PM
wkand's Avatar
wkand wkand is offline
I remember seeing one of the price lists, where the 21AXP22, was like $220 VS the 21CYP22, priced at $150. I don't think the conversion kit was any more than $10 or $15, at the time.
Maybe, the original went to air, that early.
The technician probably told them, it was a better way to go.
Not sure what you mean "Maybe the original went to air, that early". The set was 17 years old at the time of the replacement. That was a tremendous life for the original tube.
Funny that the conversion kit was only $15. if that were now, would probably be $200.
Old 09-24-2014, 06:28 PM
miniman82's Avatar
Ditto on tube life. By the time I found my CTC-4, it had like 3 hang tags in it for CRT replacement. Amazingly, the last one was dates '73 or something like that.
Evolution...
Old 09-24-2014, 07:35 PM
Originally Posted by Telecruiser View Post
I suspect he real reason it was changed is the insulator used for the metal tube had a very bad habit of breaking down and would start arcing at some very inconvenient time.
Just curious, were your folks smokers?
Tobacco soot + high voltage can really collect dust in a hurry (we've all seen what smokers sets look like inside!) so if they were that might account for the frequent problems.
Old 09-24-2014, 08:08 PM
tvcollector's Avatar
I with you on that.. I'll probably plug in the set I just got from ebay that got totally destroyed during shipping.. Watch it go up in smoke.. Hell, I may even help it..
Old 09-24-2014, 09:31 PM
On my Wingate (ctc-5) there was a crack in the plastic, the arc from the metal cone shot up thru that to the dag on the plastic. I had a spare plastic shroud so I just replaced it, I did seal the orig with some silicone but never tried it out.
I have another ctc-5 (metal cabinet faux blonde finish IIRC) that has the special chassis, not the delux like the wingate has. I really need to get on that one and see if its ok. I got it from a local guy, mainly as a back up CRT, as he said he never had it going and was told it had a bad flyback, but I have heard that so many times and found that not to be the case. It looks OK so I am hopeful it will be fine.
Old 09-25-2014, 12:33 PM
DavGoodlin's Avatar
Motorola Minion
Originally Posted by Sandy G View Post
Ahh HATE Yew...-Yosemite Sam, Esq. (grin)
And I second that, my Gramma had one of these! Congrats!
-Dave G
Old 09-25-2014, 01:29 PM
I was referring to the set with the AX to the CY conversion. It might've been a service contract replacement. Color CRT rebuilding, in the late 50's, wasn't as common as B/W rebuilding. Also, the mortality rate of rebuilding any metal coned CRT was poor and the prices reflected it. They were a lot more expensive, than they're all-glass counterparts.
The 24's, 27's and 30's, only had a six month warrantee.
Old 09-25-2014, 09:20 PM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
My father smoked. Maybe that was the cause of the problem. Thankfully, I never picked up the habit.
