well i will tell you i have done this befor with the reg tube cap off but now the chassis is on still on top of the cabinet and each time i have done this it did go to around 25kv and also did it with the crt plug off as well its only once the crt plug is put back on then the hv drops and it has been said that something is loading it down. either in the circuit or the crt itself.
