Old 11-21-2014, 04:03 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
More than likely it will work. They are hard to test without the battery pack. The adapters are 12V DC 1/8 inch jack(like a earphone) with the tip negative. The chassis' have a positive ground. Opposite of what you expect, Using an adapter with a positive tip will burn up the output transistors and output transformer. They are easy to work on. I had to adjust the FM oscillator since it was off a bit. I used a factory manual but it was wrong but I figured it out. Very good radios and pick up a lot of distant stations.
