Old 01-01-2015, 02:47 PM
Originally Posted by DaveWM View Post
Did you ever check L14 (coil from service switch to cathode leads of crt) that I mentioned many many post and threads ago? if the swap shows the issue is with the chassis and not the CRT I would suggest you check that while the chassis is out.
yes i did check L14 the ohms, compaired to the sams. if im correct i didnt cut it from the circuit i just measured the ohms and it was where it should be so i didnt feel i should remove it from the circuit.
