Old 01-03-2015, 02:27 PM
Doug66 Doug66 is offline
Need some hep with Coil
My L15 sound take off coil arrived today, and I have a couple of questions before I install it. The Miller replacement coil 1471-a has a resistor soldered across two lugs and also has two 4.7 caps.
The guy at Moyers, where I bought the coil, emailed me and said that his book said to delete them if my old coil doesn't use them. Therefore I will take out that resistor. However, the old coil uses two 33pf caps which I replaced. Should I keep the 4.7pf caps in the new coil or change them to the 33pf caps?
