6AL11 is 1/2 audio out & 1/2 audio detector.
http://tubedata.milbert.com/sheets/127/6/6AL11.pdf Bad part is most likely the detector if its a buzz. Also if the out section were bad the hum wouldnt go away with the VC turned down. As a rule hum= output buzz=detector hiss=sound IF. If its not the tube watch for open coils, the set must be getting brittle & moving things can do it. DO NOT tweak the coils !!!! ![]() 73 Zeno
