Old 02-07-2015, 06:03 PM
Zenith6S321's Avatar
Zenith6S321 Zenith6S321 is offline
Before I started to do an IF alignment, I took some pictures of some video test pattern waveforms taken at the input to the first video amp. All the tuner and IF tubes have been tested and swapped with not much difference in the ringing. I used my Sencore VA62 to generate a channel 3 RF signal displaying the single vertical and horizontal line cross. The first video amp input scope picture shows the ringing. I then set the VA62 to generate its 10 section multi-burst which is a set of white and black vertical lines of increasing frequency from 0 to 4.5 MHz. The second picture shows the poor frequency response.
