  #40
Old 04-09-2015, 11:34 AM
Originally Posted by Tom Albrecht View Post
If it makes you feel better, I will admit that an electrolytic cap exploded in a set I was working on last night because I accidentally connected it to the filament pin rather than the cathode. Just a little 5 uF guy, but still a pretty nice "pop." We all make mistakes! Good luck as you continue your project.
To adjust the range of the hold control, see my post further up this thread about changing the value of the resistor in series with the hold control.
well what i just did was take out the 3.3meg and put a 2.2 meg and its fine and got range on both sides. and i put the 220k resistor in for the blanker and those lines are history, again thanks alot...
