Old 04-28-2015, 06:57 PM
tvcollector's Avatar
Adjusting the Horz EFF coil has made the current go down to around 197 - 205 ma under the HV output tube... I replaced the the 1k resistor and voltages go down to where they should be under horz reg tube..
Perhaps maybe the EFF coil could be an issue too seeing how it's right next to where the cap exploded..
Still under horz reg tube the voltages are still low at pin 5.. and HV probe at anode still shows only 5000kv
