L41 is the focus coil check the terminal guide 1234 and compare with the coil on the sams and check the ohms 28.5 x2 and a 42.5 but you may have to clip one end of the resistor thats there. really high ohms its bad really low ohms its bad it should be at a happy medium. turning the coil stick wont change anything but disconnect what is on it to get an accurate reading , it is a pain in the ass.
