Old 07-24-2015, 08:15 PM
Originally Posted by Captainclock View Post
Actually I could barely tell if it was a 3 or a 2 or a 1 that was written in on that description for how to restring the tuning knob, and actually I tried restringing the pulley and tuning knob like the diagram said (I even used 2 turns around the tuning knob) and the tuning knob would just turn freely in between the string that was wrapped around it and it didn't even try to engage the tuning mechanism, also what I meant by the diagram for restrining the tuner on the rider's wasn't very clear about how it should be done is that they didn't indicate very clearly which way the string was supposed to go out of the pulley during the initial restringing process (getting the string out of the pulley and towards the smaller pulleys and then towards the tuning knob) I had it going out of the right side of the pulley and then towards the tuning knob and back but that must of not been right because that's where I had the issue with the tuning knob not wanting to move the tuning mechanism and just spinning freely between the string.
Also you didn't really answer my question concerning how I should approach going about repairing the chewed up wires from the output transformer.
UPDATE: I finally got the tuner restrung but the thing nearly kicked my butt in the process!
My butt has been seriously kicked by the same problem.
I meant to address the chewed up wire issue, but was in a hurry to get going this morning. If the leads are long enough, just cut off the damaged part and reconnect it to the socket terminal. If the lead is too short, use shrink sleeving or any kind of sleeving and reconnect the damaged lead. I've even used electrical tape.
