Old 08-04-2015, 07:19 PM
If it's only on some scenes then perhaps the signal is overloading the set? Or Macrovision is causing a problem. What is the picture source?
Old 08-05-2015, 01:14 AM
Tubejunke's Avatar
i went over all resistors unless i missed one but i dont think i did but these lines and rolling i cannot find whats going on here. i subbed tubes and changed resistor values around on the vert hold and vert size but no luck. if i shorten the pic top and bottom with the vert size it will become better stable but i cant widen the screen up and down because it goes crazy.
First I want to apologize. I didn't click on your pic and look closely before assuming that you had retrace lines. Also, I agree if you have a nice, bright CRT you wouldn't want to dim it to the extent that it would take. Frankly, it's bad enough that I can't imagine dimming it making it better unless it was way dim where things are indistinguishable from one another.
I think you were in the right circuit from the get go and I agree with Eric. You have some nasty vertical linearity issues. I used your quote as I noticed (even yesterday) that you say that you "changed resistor values around." That concerns me a bit, but I don't think that you said that whatever you changed made anything worse, so maybe that's OK. It just sounds like you experimentally changed some values as opposed to correcting out of tolerance resistors.
Anyway, the problem is the reason you did that, so what is causing it? A good look at the shot makes me ask if the raster is folded over with the adjustment pot set way too high. That can give the widening traces for sure, but you see them upside down. Maybe a couple of things going on there as far as component issues and adjustment. If you recapped it then the safest thing to say is to check all of your solder connections really good and look for solder drips that have fallen and bridged something. Maybe go over your cap values listed in the schematic from what was installed. There might have been a mistake that took a while to damage a cap and to show its self on your screen
Don't waste your money changing more potentiometers. If you check pots out good with an analog ohm meter and you seen no issue; then there is very little way there can be one if any. Good luck with this! Can you post a pic of the set together and working. We all would probably like to see it. I know I would.
Old 08-05-2015, 02:30 PM
well i come to see now that there are some channels that dont have the lines at all and the source is directv box so maybe its an I F issue because i originally had to turn 2 adjustments to get sound and a picture on channel 3 which both are excellent now so maybe something is out alittle affecting certain channels. and i got this hum that sounds like ac hum in the audio when the volume is at minimum but raise it alittle the hum is gone, and sound is good. is funny i have another set ts18 with none of these issues but this one ts4d is almost the same chassis but i have these issues.
Old 08-05-2015, 02:38 PM
[QUOTE=Tubejunke;3140195]First I want to apologize. I didn't click on your pic and look closely before assuming that you had retrace lines. Also, I agree if you have a nice, bright CRT you wouldn't want to dim it to the extent that it would take. Frankly, it's bad enough that I can't imagine dimming it making it better unless it was way dim where things are indistinguishable from one another.
what i did try was putting the right resistors in where they were wrong, made no difference. the brightness resistor, 1 meg but had a 2.5 meg in there and there was a 150k where it was supposed to be a 100k and these resistors were for sure factory so i left the 100k in. but i left the 2.5 meg in the bright circuit as well because when the lines appear they are not bad but putting the right resistor in , 1 meg the lines are really bad when they appear. so i guess ill leave it alone for now.
Old 08-05-2015, 09:27 PM
If it is a Moto TS-4 chassis if an original looking resistor is labeled different from the schematic, consider the schematic to be wrong. The TS-4 went through SO Many production changes that there are literally sets where there is no version of the schematic that is exactly the same as the set....Unless it looks like a part was changed by a previous tech assume it is original and correct (though there may be a 'better' version of the circuit in print).
Old 08-06-2015, 09:09 AM
ok i can see that so ill assume that maybe the oscillator in the I F @ R F is not running right because some channels dont have the lines and others do. i noticed this last night that a high channel didnt have the lines but switched to a lower and they were there.
