Found one
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 12-16-2016 at 08:36 AM. |
Thanks for all the help you guys gave me. I just got the set back in the cabinet, and it's playing well now. Some previous owner decided to recover he red tolex with brown contact paper. I tried peeling off part of the contact paper, but it ripped part of the tolex. I bought some red tolex and am going to start by recovering the lid. Then I will pull the chassis back out and tackle the rest of the cabinet.
This was a good thread for anyone with a series set. I have the same set with worn and faded tan covering. Red seems like a good idea. Eric H had attached an advertisement for it with red tolex, which looked right with all that gold trim. http://www.videokarma.org/showthread.php?t=262373
I got side tracked but its still on my bench I replaced the electrolytics in mine, then powered it up slowly and there is a short in the filament string causing the 12BY7 to light up bright, with the remainder dead. I will replace the fusistor with a CL60 thermistor, series fuse and resistor. Great Idea.
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 09-27-2015 at 10:42 PM. |
I have this exact same set except it is branded Canadian Marconi
Gregb |
