There are some limits to what you could do here..... For starters, you could probably
only easily adapt tube to tube H output things, first drive coil winding voltage, which gets you into the ball park for output voltage, same with current. And there are all those other taps mentioned above. Tube circuit impedance's, don't forget the yoke is also part of that circuit too.... There is lots to think about here.... Better to rewind a correct part that has failed, than to try and re-engineer a 1/8 of a tv to fit in a part that may not last too long when yer done.... .
