Old 11-19-2015, 07:07 PM
If it is a VT-71/TS-4 chassis variant and still uses the ballast, then that will provide inrush limiting.....If it has been replaced, then it should use the capacitor ballast replacement method to provide inrush limiting.....
The 250v 10uf poly caps for replacing the ballast resistors, 150 ohms, would any poly cap rated 250v 10uf be the same because I found caps with this rating on eBay and it is said in the auction that they are for audio systems. I would think they would be ok for using in the set to soften the currant rush, but all you pros would know better then me, lol.
