Yes, an active converter such as the two listed above is required.
I'm a bit curious about the cable you got, though. Where did you buy it? I can't think of any application in which such a cable could be used and I wonder if it is a scam. Somebody please enlighten me if there is a use for a straight cable like that without active devices in between. |
