Old 01-18-2016, 01:13 AM
Outland Outland is offline
CRT Issues
I've been seeing two problems on a 1994 BPC Panasonic set I have.
The first is a bending of the top few lines of an image.
The other is an impression of an image to the right of anything bright or shiny.
Is this a CRT issue or something repairable?
Old 01-18-2016, 01:36 AM
Not CRT issues, in my experience. The bending may just be a horizontal-hold/frequency adjustment internally. Did you have this set working without these issues in the past, or did you get it this way?
Old 01-18-2016, 01:42 AM
I think the shadows to the right weren't there before. Not sure about the bending.
The set had an issue with a bad joint in the vertical IC that would compress the picture periodically. A whack also temporarily fixed it.
Old 01-18-2016, 07:48 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
edit.. delete after re-looking at the pic, top looks like a bit of "flagging" used to be common with VCR playback and certain TVs. Horizontal timing I recall was the issue.
Old 01-18-2016, 12:38 PM
Do all video sources show the bending? Is the ghosting/ringing equal with composite-video as well as S-video and RF inputs? It could be something like loose grounding/shielding or wiring in the video circuits.
Old 01-18-2016, 10:09 PM
The bending doesn't happen on all sources, as far as I can tell. The ghosting does happen with all sources though. Capacitors?
Old 01-19-2016, 04:00 PM
Yes, bad ones in the video circuits could cause that. I would expect to use an oscilloscope and trace input signals through the set at this point.
Old 01-19-2016, 05:23 PM
All sets can show a little bending at the very top with VCR playback, even those designed after VCRs came into use. It will vary with different tapes and VCRs. If it is within the first few percent of the raster, just turn up the height a little to hide it off the top of the screen. If it extends very far from the top, check the capacitors and resistors in the horizontal AFC section.
Old 01-19-2016, 05:38 PM
You could also put a TBC between the VCR and the TV to fix the VCR signal so that it no longer causes bending.
Old 01-19-2016, 06:28 PM
It happens with DVDs too. Is the ghosting bad caps too?
Old 01-19-2016, 06:32 PM
I have a couple of late Panasonic tv's and they have a number of bad solder joints
that have caused all kinds of strange behavior. One of them had bad connections
along the tuner, kind of a unit by itself, lots of bad connections caused a lot of the
poor definition I see in your pictures, especially the "stop" Picture. If not all devices
have the bad look, then you might have to look into the impedance matching
transformer and the other stuff inside the tuner near the input.
Old 01-19-2016, 06:56 PM
How can I start diagnosing/working on the problem?
EDIT: There's only one input, the coaxial RF.
Old 01-19-2016, 08:52 PM
If there is only an RF input, a small amount of that kind of ghosting on fine details may be normal; also, any set made in 1994 with only an RF input is by definition a low-end set, so again it will not have the picture quality of higher-line sets.
Old 01-19-2016, 08:54 PM
If it was my set, I would look inside for the horizontal-hold/frequency adjustment and try tweaking it, and not worry about the ghosting at all.
Old 01-20-2016, 03:46 AM
Noted, I'll do that.
Thanks all.
