Old 01-24-2016, 10:58 AM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
What Calipers do I Need?
I need to measure an axle for an e-clip, but the clip is supposed to slide into a very narrow groove on the shaft. I'd say finger-nail width. The calipers I have don't go that narrow. Does anyone have a recommendation for calipers that can fit into a tight space, and have very narrow teeth?
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
Old 01-24-2016, 11:11 AM
Since the clip is springy, you only have to get "close" with your measurement. If you use a thin bit of wood -- like a flat toothpick -- and place it in the bottom of the groove, then mark the depth with a sharp knife (not a pencil or pen), you can then measure that with your calipers. Double the depth and subtract from the diameter, and you'll have your target e-clip minor diameter.
Probably a dozen other ways to measure it, too, depending on what you have to work with.
You can buy assortments of e-clips at places like Harbor Freight. They also sell calipers with knife-edge jaws that should get down in the groove.
Chip
Old 01-24-2016, 12:27 PM
Since e clips come in standard sizes, I suspect that you could guesstimate close enough and obtain perhaps a couple of sizes to try. Check the sizes listed in this assortment:
http://www.amazon.com/ATD-351-300-Pi...ywords=e+clips
not affiliated,
Old 01-24-2016, 04:34 PM
Dubis7's Avatar
. Check the sizes listed in this assortment: jr
I actually bought that package awhile ago (Or I at least believe it was that one) and found that the smallest one was two small, but the next one up was too big.
Old 01-24-2016, 06:58 PM
Metric perhaps?
http://www.amazon.com/Piece-Stainles...ZZ2DVCQBMRQTB6
Or in between size, such as 3/32?
http://www.amazon.com/Pico-6210C-E-C...=3%2F32+e+clip
not affiliated,
Old 01-24-2016, 07:18 PM
This may sound a bit asinine, but I've been known to crush larger ones down to fit, and bend smaller ones open to fit....Crude but effective.
Old 01-24-2016, 10:25 PM
I must admit that I have done that as well.
Old 01-26-2016, 12:04 AM
Dubis7's Avatar
Do they make calipers specifically to fit smaller spaces? I've heard the term "blade calipers" before, would those work?
I really don't want to drop money guessing on the size - I'd rather pay extra now to get the tool I need so I'll have it in the future.
Old 01-26-2016, 12:12 AM
Dubis7's Avatar
Metric perhaps?
Definitely SAE. Made by RCA sometime between 1959 and 1960 in USA.
That's what I figure, yes, but that leaves a huge range of what size it could be.
I actually did do that for awhile, and it seemed to work. But I'm being perfectionist on this one because, near as I can tell, not a lot of these were made, so I'm trying to make sure the repairs I do will hold up long term.
Old 01-26-2016, 07:43 AM
It would probably be quicker to grind one to fit, starting with the closest too-small size. Dremel grinder with pointy stone wheel, and the part in a real vise, or vise-grip pliers. No hand-held. Contour three lobes and Bob's your uncle.
Since they're hard, springy steel, drilling won't do the job.
Chip
