Old 06-03-2016, 07:21 PM
Do you see the straps on the sides of the shield? Unscrew the straps from each other and the shied will unwrap it's self from the CRT. Lift CRT from the shield. The proper installation order is to put the shield in the cabinet, bolt the shield corners down, set the CRT in the shield from the rear, fold the shield around the CRT and tighten the side straps of the shield.
Hope that makes sense.
