Old 06-16-2016, 10:02 AM
Major points are
Hoz out in front of yoke plug
hoz drive transf to left of h out
hoz drive transistor to the left of it.
LV regulator on black heat sink with model tag.
Vert outputs are 2 transistors on small sinks
near hoz drive
If you got a HV probe see how much its coming up.
If not you can do the same thing at the 200V.
Go to CRT socket. There are 3 larger resistors same
value. where they join is the 200V. See how much
it comes up. That gives an idea of the HV level.
