Pilot tv resistor for crt
I'm thinking of putting a separate filiment transformer for the crt in my pilot. What I would like to find out is what ohm and watt resistor to put in place of the crt filiment, the best that would mimic the crt so as it don't affect anything in the heater string.
3KP4 data sheet here:
https://frank.pocnet.net/sheets/049/3/3KP1.pdf The first two lines of data are the heater parameters... An ohms law calculation will give you the answer. jr |
Easier way to go would be to place a bi-directional TVS diode across the CRT filament. Done.
I used this one: Diode part no. P6KE8.2CA-TP. Got it here: https://www.arrow.com/en/products/p6...ponents#page-1 Just follow the wires from pins 1 and 11 of the CRT (Heater). Wherever they connect in the set, put the diode across those two tube pins. Protects the CRT from the start up surge and no separate transformer needed and no need to compensate for the missing CRT heater in the rest of the string. If I remember correctly, I had to extend the leads off the diode, but installation took about 5 minutes.
-Al Last edited by bigaudioal; 06-16-2016 at 03:49 PM. |
-Al |
I've used the P6KE7.5CA - keeps it real safe at 7.5V, and a buck gets you 10!
My Silvertone 21" consolette and Emerson luggable are still going strong with them. Cheers,
Hey findm keepmm is that SAMs you have the 95-6 is that the 208tr does it show a ballast or 6x5 . Could you tell me what value Micas are shown in the verticle section of your 95-6 SAMs .
