Old 07-24-2016, 09:19 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Did you measure the cabinet? It looks a bit narrow for the set, but then again the photos lack sufficient reference of scale for me to tell with accuracy.
the Heathkit escutcheon is just a shade under 28 inches wide. The inside of the cabinet measures just over 28 inches wide. I tight fit, but it will go in there once I move the inside shelf down about 10 inches. I'll need to add some trim to finish the front off above and below the escutcheon and then install a speaker baffle and grille cloth at the bottom, but I think it will go.
