Old 12-04-2016, 11:51 PM
EdKozk2 EdKozk2 is offline
Tinker
Hi Doug66,
Did you replace the vertical output transformer with a 4-wire type or a 3-wire type ? If you changed to a 3-wire type ( Stancor A-8141 autoformer) then your connections would follow note #10 instructions in the Sams. If you have a 4-wire type then follow the schematic as shown. The original vertical output has a 1700 ohm primary and 6 ohm secondary.
As for pin 3 of the damper that is the boosted B+.
Ed
