I too have seen the sets side by side at the ETF. The CBS (Gray) wins, the
Westy is next, the RCA third. However ... neither the Westy nor their RCA 15GP22 set compares to my CT-100. Mine is not quite as good as the Gray ... but most of that is the fault of CT-100's poor Q first video amp. They put too much worry into chopping of the response at 0.6 MHz. Its better to let it fall gradually and smoothly out to 1.1 or 1.2MHz. The CT-100's overall color rendition is excellent if its set up correctly. Remember ... there are 81 adjustments to get right. A CBS set has about half that since most of the work is in the (solid state!) NTSC to sequential converter. |
