Hey I'm just passing along tips and hints from two of the guys that were in RCA's color products division back then... at this juncture there are no questions that aren't worth asking. You're still stumped.
How does the dag look on your 15GP22? Are you 100% positive the dag has a good solid connection to ground? Harry had a set (21 incher though) where the connection between the good looking dag and ground was intermittent. The arcing caused excessive HV current draw and had a tendency to pop fuses. Is your CRT a rebuild? Harry said factory rebuilt 15Gs (ones that never made it through the initial processing) are more failure prone (gas or arcing) but he never explained why....? |
