Old 03-22-2017, 03:56 PM
C-75 could be shorted, but I doubt that the horizontal would work ok if it was... a real head-scratcher.
That's a 900mmf that cap along with the other Micas were changed but each one I replaced I tried the set and after all of them were replaced I was left with the same problem. I checked the horiz afc and block trans and ohms are perfect. So I don't know what it is with pin 2 or if it even has to do with this odd problem.
