Old 03-23-2017, 06:30 PM
EdKozk2 EdKozk2 is offline
Tinker
Timmy,
Did you ever try spraying any cleaner into the vertical hold and size control to see if it would stabilize the vertical roll? Did you try wiggling V9, V11, or V12 while the set is on to see if it helped? I come across worn and dirty contacts all the time in old equipment. The cause of all sorts of issues. Just because parts are swapped or tested doesn't always eliminate the root cause.
Do you understand how the vertical feedback loop works with this set? If you have a scope, check to see if you are getting the proper trigger signal to your vertical oscillator grid from the sync separator/ integrator network.
Ed
