Old 03-24-2017, 03:52 PM
[QUOTE=EdKozk2;3181220]Timmy,
I compared the Sams schematic to the Riders for the TS-18 chassis. There seem to be a few differences and maybe errors. I' ll use Sams part numbers. Resistor R-59 should be 22 meg not 2.2 meg. Resistor R-56 is shown as 150K ohms not 100k. Also make sure C-61 through C-68 are the correct replacements,
voltage and tolerance wise. If trying these changes don't slow down the vertical then you can try increasing the capacitance of C-64.
Ed[/QUOTE
Well it is a ts18 but the resistor I pulled out judging by the colors was a 2.2 and it's weird that the riders would say a 22 meg goes there. This chassis was never touched it had all the old wax caps and where r56 is it's definitely original 100k and the Micas don't show a voltage but the Micas I put in are the same ones in my other tvs , ts4d, ts18, and so on and are rated for 500 v and may be a few rated for 1000 v other then that all the caps that replaced are 600 v .
