  #32
Old 05-24-2017, 08:35 PM
Sure looks like Syncroguide to me.
Here are a few possibilities.
Flyback is bad or hooked up wrong - Check your wring and check the resistance between flyback windings. Should be close to values shown on scheamtic
Horizontal oscillator running way off frequency. Check waveform on pin 5 if you have a scope.
Weak drive signal to 6BQ6 - Does adjusting the horizontal drive do anything ? Check DC voltages on 6BQ6 too.
The schematic must be the Syncroguide version, not the set the OP is working on!
The OP is referring to the .0039 cap across the horizontal lock coil.
The chassis should have a horiz phase det tube like a 6AL5.
