Old 06-26-2017, 05:09 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
I checked the heater voltage from the 8080A. It was probably 6.7 volts for the previous test. I adjusted it to 6.3 volts and ran it for 90 minutes. This time it took about 2 minutes to peak at barely over 0.2 mA, then slowly decreased to 0.15 mA where it stayed for the entire test period--then dropped to less than 0.05 mA in a few seconds.
Entirely hopeless? Even if it's hopeless I'm going to play with the restorer just to see if the meter and indicator lights work.
Winky Dink
Damn the patina,
Full speed ahead!
