My new CTC-15
Got this CTC-15 today for only $32. It had the original tube, but it was replaced because I wanted the rare earth phosphor.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. Last edited by Celt; 09-16-2017 at 07:47 PM. |
Sweet! And inexpensive too!
Good lookin' set!
Let me live in the house beside the road and be a friend to man. |
Finally fired up the CTC-15. Check out that incredible picture!
Quality vintage television service by Alabama's original Animegao Kigurumi performer. Last edited by Celt; 09-18-2017 at 09:58 AM. |
Noice.
Nice! I've been after something similar for a few months now. I'm still convinced no one in my neck of the woods had color until the solid state era......
also that Futurama subtitle is hilarious
Great find. As you're probably already aware, the two ground stakes on the far right end of the chroma board exist in two states: either cracked or gonna crack soon. They need to be re-flowed as a matter of course on every CTC-12, '15, '16, '17 and '25.
When they fail, the heaters on the 6GU7s go out, causing the plate voltage to rise. Since the plates are DC-coupled to the CRT grids, this makes the CRT beam current go nuts, lugging down the HV supply. Pic blooms, loses focus and fades out. |
Very nice set. If you have your other tube I'm interested. Have a CTC11 I would like to improve. Thanks
Tom Smrz |
Had to trade the old tube for the new one.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. |
Well, I'm fighting my first battle with the CTC-15 already. The CRT keeps randomly loosing filament voltage. I took the back off, inspected the socket and CRT base, and put a drop of Deoxit on the filament pins, and that fixed it. I put the back cover back on, and it's out again.
PROBLEM SOLVED. Had to heat up the CRT pins.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. Last edited by TUD1; 09-18-2017 at 08:36 PM. |
Heck, take it back for a warranty claim on the CRT.
![]() Looks nice... |
This is becoming the most problematic TV I've ever owned. I had to fix the CRT filament again last night, and I decided to just leave it away from the wall with the cover off. It was working perfectly fine when I went to bed, and when I got up today, I had no blue, no red, and a whole lotta green. I tried swtching the 6GU7's around, and after that I got no green, and whole lotta purple. So then I go find another 6GU7, and put it in the G-Y/blanker tube socket, and the green was still dead. I'm at a loss.
Has the solder ground stakes/traces on the chroma board been reflowed?..If not then you will want to do that.
New tubes, clean sockets, solid solder joints, FTW.
