Old 09-24-2017, 06:44 PM
Findm-Keepm's Avatar
Followin' the Rules...
Be careful not to sand or rub through to the gloss or you'll have shiny spots. Also semigoss is made by adding a fine particulate to gloss. If its uneven in thickness, you can get an uneven sheen. Another option is to only use gloss and control the sheen by rubbing it out with a courser grit
Originally Posted by Crist Rigott View Post
Bob, good info. Thanks.
The Smithsonian called - you guys are making them look bad....
Freaking awesome restoration, I must say.
Brian
USN RET 22YRS (Avionics/Cal)
