Old 10-16-2017, 07:50 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
Originally Posted by miniman82 View Post
Before you assume your current yoke is beyond repair, how about trying to repair it first? I’ve seen yokes before that had some corrosion on the copper wires near where they join to the solder lugs, and a cold solder joint isn’t outside the realm of possibility either. Poke around, not like you have anything to lose at this point.
The windings that fit on the tube neck have an area of corrosion and I believe i see a broken wire and almost all the varnish on those windings are gone so its shorting too. Its dead.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
