Old 10-22-2017, 09:51 PM
Originally Posted by miniman82 View Post
I’m only across the peninsula from you, if you wanna play with my roundie test jig.
Someday I have to come up with an excuse to see your collection! I played with the set for about an hour this morning without trouble. I seem to recall this same issue with an early bw set, maybe my 721TS, where the vertical osc seemed to need a "kick-start".
The convergence so far hasn't been as far out as I thought; mostly it was the static convergence being off. I can't quite figure out what caused it to change like it did. Could it be tied to the DC circuit they used on the -5?
