  #35
Old 10-29-2017, 06:07 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Originally Posted by MadMan View Post
What Tom said makes sense, link the tuner shaft to the tuner of a little fm radio. You could use an o-ring, or similar rubber belt, maybe. If you get it tensioned, turning the tuner will turn the fm tuner also, but it can slip too, providing for the difference between the two tuners. Better yet, get an fm radio with a digital tuner, and rig it to tune with a rotary encoder switch, and belt THAT to the tuner shaft.
If I can't use the Pye's gang capacitor to directly tune the FM radio I would likely find a way to mount the one from the portable to one end of the gang's drive shaft and run wires to the board under the chassis. As far as I know they all rotate a half turn so I wouldn't have to concern myself with pulley/gear ratios.
By the way I got the dial glass cleaned up. It was pretty filthy on the back too so after a quick test to make sure a light wipe with glass cleaner wouldn't damage the printing I just went to town on it and now it looks great.
