Moving to the upper part of the chassis I decided to do the terminal strip near T3.
Pretty routine and nothing special to report except I had to lengthen a lead on R84 a 100 Ohm resistor. What I do is trim the one side to about 1/4 inch length. I then use some 22awg bus wire and attach it to the trimmed lead using the coil method. I then figure out how long the lead needs to be and slide a piece of 1/16 inch heat shrink tubing down to the coil. I then shrink the tubing and then use a 1/4 inch long piece of 1/8 heat shrink tubing to cover up the coil. ![]() ![]() ![]()
