Old 11-23-2017, 10:27 AM
Hmm, I wonder what is so different , it looks the same along with the gun.
The difference is the the heater current and voltage. 8.4 volts@ 450ma.
These tubes were used in RCA's and Westinghouses with 450 heater string, 17DQ6, 17AX4 etc.
A 50 ohm 2 watt resistor in parallel with the 14at heater would work OK.
