Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > The Amateur Radio Spot
Old 11-30-2017, 10:56 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Pretty easy to rebuild. Only thing that you need to watch for is the voltage if it doesn't have a switch for low and high. You can wire it internally one of two ways....low power and high power. The multi-banders take the higher voltage, and the single banders take the lower voltage.
