Old 12-26-2017, 07:22 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Originally Posted by Jon A. View Post
I've seen a bad distributor pickup coil cause that. Often times it was a bear to get the thing re-cranked, not to mention pulling over without the power assist which is probably harder than actual manual steering.
Been there.. The taurus stalled once in traffic and luckily it re-started. The problem was random for awhile there. Finally, it threw a "check engine" light and my neighbor brought home his SNAP ON scanner from work and pulled the code. Then he researched mitchel on line and narrowed it down to the crankcase sensor. I admit i was skeptical when i changed it out, but its been smooth ever since..
SR
