Old 01-18-2018, 07:58 PM
Regarding the sound, you might try disconnecting that auxiliary volume pot, and connecting C7 back per original. The pot is forming a voltage divider, reducing plate voltage on the 1st audio tube. That might be causing degraded audio (or might not).
The way you had the volume pot connected was semi-correct. You need to use a cap .02 to .05mfd between the plate of the 1st amp tube and the high end of the volume control. The wiper would go to C7 and the low end to ground, as you had it. It should correct your distortion problem. You might have distortion after this fix if you are tuning to a 50KW station during the day. Then you would have to back off on the sensitivity control.
