Old 01-18-2018, 09:33 PM
Originally Posted by TUD1 View Post
I wouldn't worry about the flyback. My set is on its third CRT, and would I feel safe watching it for hours, but the flyback had to be "rejuvenated." That is to say, when you get it working, don't watch it for hours without letting it cool down. You need to slowly cook the moisture out of the flyback. If you start smelling it, shut it off immediately and wait a while before using it again.
They can be reliable (I had a Silvertone CTC-15 clone in daily status for ~5 years) but always check and dip the cathode current with the lin/efficiency coil. Sam's usually has a typical and a max spec...Get too close to the max and you're on shaky ground.
Old 01-18-2018, 10:01 PM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
It is an RCA clone chassis.
You sure about that? I had been under the impression that this is an Admiral creation. Chassis number is 24A2.
Good to hear. I was just watching your video on youtube again today... yours sure does have a nice picture.
Old 01-19-2018, 09:06 AM
The set is an Admiral build 100%. If its a copy of the RCA I
dont know, I dont remember the tube line up.
These sets can give an unbelievable pix, as good as any.
