Old 02-26-2018, 08:29 PM
The last model that I repaired was similar to the one pictured, with the crazy colors, was a black base with a gray speaker grill, tone arm and spindle top cap.
The cartridge was bad and the only one the RCA distributor had was the low output one. This phono had the one tube amp, 25L6 in series with the motor and the output was low. The owner wanted it back as-is.
Interesting! I have a similar model (7-EY-1DJ) that is black and grey with a white cap and tone arm....also a cheap o model with only a 4 inch speaker and a 50L6 amp with 35W4 rectifier. May have to follow E/M s lead and add a pre-amp tube, if I ever restore the thing.
